Specify Component Data with Expressions
When a data component can be expressed in terms of another, it is unnecessary to include the full set of values for both.
The derivative values can be computed by the program when the file is read. In this case, the component data is specified by abfDefineComponent(), which takes an expression string as its parameter, it is not specified by abfAddReals().
There are two methods used to refer to other components.
To reference components in the same request when the file being translated contains X, Y and Z components, the magnitude of the vector can also be designated by these values. This is done by passing the expression, sqrt(c0 * c0 + c1 * c1 + c2 * c2), to abfDefineComponent(). The variables, c0, c1, and c2, represent the first, second and third components in the request (numbering begins at zero).
