In Altair Binary Format files, data is stored at the
component level. The default data format is eight-byte floating point values.
The ABF library also supports one-, two-, four- and eight-byte integers and four-byte
floating point values. The following ABF statements allow you to change data
representation:
- abfDefaultPrecision()
- Changes the default precision (in bytes) of all data.
- abfSetPrecision()
- Overrides the precision for the currently open component.
- abfUseFloatingPoint()
- Determines whether the data is treated as floating point or not.
Use abfOpenDatatype() to open the datatype of the
component.
Use abfOpenRequest() to open the request.
Use abfOpenComponent() to open the instance of the
component.
Use abfAddReals() or abfAddIntegers() to
transfer a copy of the data to the ABF library.
abfAddReals() and abfAddIntegers copy a
block of specified values and can be called multiple times to append data to the
existing values.
abfAddReal() and abfAddInteger() append
a single value to a component data set.
It is important to use the function that corresponds to the data type (integer
or floating point) being specified. Using
abfAddReal() to
specify integer data or
abfAddInteger() to specify
floating-point data produces incorrect results.
Note: Close each component,
request, or datatype as it is no longer needed. Only one of each can be open
at a time.
