PreSimulation Tool
Overview of the PreSimulation Tool user interface.
LS-DYNA
Option Description
Unit System Selecting a unit system will automatically set up the default simulation parameters to the correct unit. In any case, you can still modify these values manually.
Dummy Dummy components that are selected in contact with the seat will be exported for the pre-simulation. The selection can be done via:
Components
Mechanism
Opens a dialog to select a complete dummy
Assemblies
Set
Opens a dialog to select a set of type *SET_PART_LIST
Seat Select the seat components that will be exported for the pre-simulation. The selection can be done via:
Components
Mechanism
Opens a dialog to select a mechanism defining the seat. Only the bodies that are defined by components or sets of components will be taken into account.
Assemblies
Set
Fixed Nodes of Seat Select the nodes that will be fixed during the simulation. The selection can be done via:
Nodes
Set
Opens a dialog to select a set of type *SET_NODE_LIST
Dummy Displacement Direction Defines the vector in which the dummy components will be moved to the starting simulation position when penetrations with the seat are no longer detected.
Export Files Defines the pre-simulation deck name and location.
Dummy Velocity Defines the imposed velocity value applied on the dummy parts during the simulation. Default value = 0.1mm/ms.
Time Step Defines the control time step value. Default value = 0.001ms.
Scale Materials Density Scale factor to scale the material density values in order to increase the critical time step of the model. Default value = 10.
Dummy Displacement Step Displacement increment used to move the selected dummy components along the prescribed vector. After each increment, the penetration check between the dummy and seat will be performed and the dummy motion will be stopped when penetrations are no longer detected. Default value = 10.
Soft Defines the Soft parameter value in the generated contact between the dummy and seat. Default value = 2.
Friction Defines the FS parameter value in the generated contact between the dummy and seat. Default value = 0.0.
Imposed Contact Thickness Defines the value of parameters SST, MST and SLDTHK in the generated contact between the dummy and seat. Default value = 0.0.
Contact Stiffness Scale Factor Defines the value of parameter SFS in the generated contact between the dummy and seat. Default value = 0.0.
Import *INITIAL_STRESS_SOLID If this checkbox is activated, initial stresses for solid elements will be imported from the dynain file. This option is activated by default.
Import *INITIAL_STRESS_SHELL If this checkbox is activated, initial stresses for shell elements will be imported from the dynain file. This option is deactivated by default.
Import *INITIAL_STRESS_BEAM If this checkbox is activated, initial stresses for beam elements will be imported from the dynain file. This option is deactivated by default.
Export Starts the export process of the pre-simulation deck at the specified location.
Import dynain File Allows the LS-DYNA simulation to update the initial model.
Close Closes the dialog.
To view a tutorial on Pre-Simulation setup, see HM-4650: Seat Deformer with LS-DYNA Pre-Simulation
Radioss
Option Description
Components
Mechanism
Opens a dialog to select a complete dummy.
Assemblies
Set
Opens a dialog to select a set of type /GRPART.
Components
Mechanism
Assemblies
Set
Nodes
Set
Opens a dialog to select a set of type /GRNOD.
Export File Defines the pre-simulation deck name and location.
Generate XREF for initial stresses Enables the creation of /XREF cards for the seat components that are compatible with this Radioss feature in terms of material type and element formulation. This checkbox is activated by default.
Friction Defines the friction value in the generated contact between dummy and seat. Default value = 0.0.
Stmin Defines the minimum contact stiffness in the generated contact between dummy and seat. Default value = 1.0kN/mm.
Gap_Min Defines the minimum gap in the generated contact between dummy and seat. Default value = 0.5.
IGAP Defines the IGAP value for the generated contact between dummy and seat. Default value = 2.
Import h3d File Allows the Radioss simulation to update the initial model.
