Standalone Applications Unit Draw
In addition to the applications listed above, there are several standalone applications that draw Altair Units. The following table is a summary of AUs drawn of those applications.
Product AUs License Feature Description
EDEM BulkSim 21 EDEMBulkSimGUI BulkSim GUI application.
40 EDEMBulkSimSolver In CPU mode, using up to 12 cores it should be a constant draw of 40 AUs.
60 EDEMBulkSimSolver In GPU mode, it should pull the equivalent of 16 cores and draw 60 AUs. Stacking on the second plus.
Embed 21 EmbedCodeGen An extension of EMBED Simulation Edition for model-based firmware development supporting all microcontrollers, and with enhanced support for the following: Arduino®, ARM®-Linux® Raspberry Pi™, STMicroelectronics®, and Texas Instruments™.
Embed Basic 1 EmbedBasic Same as EMBED Professional with a 100 block limit.
Embed Digital Power Designer 10 EmbedDigitalPower Used for the design and development of digital power supplies and power conversion equipment. DPD is an Add-on for Embed.
Embed OpenVision No No Add-on for Embed.
Embed Simulation Edition 10 EmbedSimulation A block diagram and state chart visual environment for modeling, simulation, analysis, and control system development. In addition to its simulation capabilities, it also supports real time data monitoring and control using National Instruments and other boards as well as OPC, CAN, UDP, Serial, and MQTT.
Embed Viewer No No Standalone application
ESAComp 6 ESAComp Composite design software. Units are stacked.
Flow Simulator 50 FSimGUI,
FSimSolver
Integrated flow, heat transfer, and combustion design software that enables mixed fidelity simulations to optimize machine and systems design. GUI levels. First solver instance levels, second plus stacks.
FluxMotor 15 FluxMotor A flexible, open software tool dedicated to the pre-design of electric rotating machines.
PollEx Logic/CAM None PollExEntity Logic, CAM, BOM
PollEx MFG 30 PollExMFG PollEx Manufacturing options
PollEx PCB Modeler 10 PollExBasic PCB Modeler (PCB, Real PCB Assembly Viewer, Cross Probe (CP))
PollEx PCB Solver 30 PollExSolver PCB Solvers for signal integrity, power integrity, thermal analysis.
PollEx PCB Verification 50 PollExVerification PCB Design for Manufacturing (DFM), Design for Assembly (DFA), Design for Electrical (DFE), Design for Electrical Plus (DFE+), Logic DFE
PollEx PCB Verification Post-Processing 21 PollExPostVerification PCB Design for Manufacturing (DFM), Design for Assembly (DFA), Design for Electrical (DFE), Design for Electrical Plus (DFE+), Logic DFE – Result visualization
PollEx PCB UPE 30 PollExUPE PCB Unified Part Editor
PollEx UDE Feature-based server PollExUDEServer
4 PollExUDEUser Feature-based license server with a fixed annual per socket up to 50 users.
Additional checkout for each client access draws 4 AUs.
SimSolid 30 SimSolid,
SimSolidBasic
A structural analysis software for fast design iteration. It eliminates geometry simplification and meshing, enabling the analysis of fully featured CAD assemblies without meshing. Levels at first instance, stacks at second plus.
50 SimSolidAdvanced For fatigue, incremental non-linear, and batch mode.
