Define Trim, Pierce and Lance Lines
After adding a trim operation to your analysis, you can define trim, pierce and lance lines.
  1. Select a Trim operation that you added to your analysis.
    The Trim, Pierce, and Lance tools appear on the Tryout ribbon.
    Note: If your model includes a single trim line, the software automatically identifies it. If more than one trim line exists, the longer line is identified as a trim line and the remaining lines are identified as pierce lines.
  2. Select the Trim, Pierce, or Lance tool.
  3. On the model, select the line(s) or edge(s) where you want to create the trim, pierce or lance line.
  4. Click to confirm or on the guide bar, click Assign.
    The trim, pierce and lance lines are assigned. An arrow appears for each line indicating a direction for the trimming process. The default direction is based on the average normal.
    Figure 1. Model with Trim and Pierce Lines
    Figure 2. Model with Lance Line
Change the Position of Trim, Pierce, or Lance Lines
Adjust the position of the trim, pierce, or lance lines relative to the blank.
  1. On a Trim operation you added to your analysis, click lick the Edit Position tool.
    A guide bar opens with auto and manual options.
  2. Choose:
    Software Position Description
    Auto The blank moves to the trim line automatically.
    Manual
    On the model, select and drag the manipulator to move the trim line in reference to the blank. The manipulator indicates the distance from the selected tool relative to the blank.
    Alternatively, in the microdialog, enter a value for the distance.
Change the Direction of Trim, Pierce or Lance Lines
Define the direction of the trim, pierce or lance lines.
  1. On your model, double-click an arrow that points to a trim, pierce or lance line.
  2. Use the microdialog options to define the line direction.
Figure 3. Model with Selected Trim Line in Green
Microdialog Options
Select from the options to define the direction of the trimming or piercing process.
Icon Description
Manually define the draw direction with the manipulator that appears on the model.
Reverse the draw direction.
Align the draw direction to the global X, Y or Z axes.
Align to part
Review the value for the the global X, Y or Z axes.
Keyboard Shortcuts & Mouse Controls
To Do this
Add/remove from selection Ctrl+click
Reverse selection Ctrl+R
