Predict Blank Shape
  1. From the Tryout ribbon, click the Predict icon.
  2. Click the Blank Shape icon.
  3. Optional: Click to select options for Line projection and Blank boundary.
  4. Select line that you would like to predict blank shape for.
  5. Optional: Select Replace Blank to replace existing blank with predicted blank.
  6. Click Predict.
    The new blank shape is created.
  7. Right-click and mouse through the check mark to exit, or double-right-click.
Manually Replace Blank Shape with Predicted
  1. Click the Blank icon.
  2. In the Model Browser, hide objects other than the Blank and the Undefined new blank shape.
  3. Click to remove the original blank selection.
  4. Select the new predicted blank shape and click Assign.
  5. Right-click and mouse through the check mark to exit, or double-right-click.
