Predict Trim Line
  1. From the Tryout ribbon, click the Predict icon.
  2. Click the Trim Line icon.
  3. Select lines that you would like to predict trim lines for.
  4. Optional: Select Replace Trim Lines to automatically replace existing trim lines with predicted trim lines.
    Note: You must have a single trim operation and a single trim line to use the replace option.
  5. Click Predict.
  6. Right-click and mouse through the check mark to exit, or double-right-click.
Manually Replace Trim Line with Predicted
  1. Click the Trim icon in your Operations.
  2. On the secondary ribbon of tools that appears, click the Trim icon.
  3. Select the trim line that you would like to replace.
  4. Click to remove the selection.
  5. Select the new predicted trim line and click Assign.
