Post-processing quantities: multilayers 2D method
Introduction
The post-processing quantities in the 2D problems are of two types:
- local quantities, analyzed in all points of the study domain
- global quantities, resulting from an integration, analyzed over the entire study domain or on a part of this domain
Local quantities
The local quantities are those available for the concerned application (Magneto Static 3D, Transient Magnetic 3D, Steady state AC Magnetic 3D).
The post-processing can be carried out for each of the modeled layer.
Exploitation of results on a layer or on the assembly of n layers.
Global quantities
The global quantities are those available for the concerned application (Magneto Static 3D, Transient Magnetic 3D, Steady state AC Magnetic 3D): magnetic torque, magnetic energy, …
The calculated values are the average of the values calculated over the n layers.
