Coil models and their availability in Flux projects
Introduction
The availability of coil models in a Flux project depends both on the module (i.e, Flux 2D, Flux Skew or Flux 3D) and on the application selected by the user.
The tables in the next two sections summarize the availability of Meshed Coil regions and Non-Meshed Coil magnetic sources in each module for the existing Flux applications (i.e., Magneto Static, Steady State AC Magnetic, Steady State AC Magnetic Coupled With Transient Thermal and Transient Magnetic).
Meshed coil regions
Meshed coil regions are available in all Flux modules. The availability of each subtype of meshed coil regions in the applications of each module is detailed in the next three tables.
Table 1. Meshed coil models available in Flux 2D
Flux 2D Application Coil Conductor regions Solid Conductor regions
Without losses With Additional Losses
Simplified geometrical description Detailed geometrical description
Magneto Static
Steady State AC Magnetic coupled with Transient Thermal
Transient Magnetic
Table 2. Meshed Coil models available in Flux Skew
Flux Skew Application Coil Conductor regions Solid Conductor regions
Without losses With losses
Magneto Static
Transient Magnetic
Table 3. Meshed Coil models available in Flux 3D
Flux 3D Application Coil Conductor regions Solid Conductor regions
Magneto Static
Transient Magnetic
Non-meshed coil magnetic sources
Non-meshed magnetic sources are only available in Flux 3D.
Table 4. Non-meshed Coil models available in Flux 3D.
Flux 3D Application Non-meshed coil
Without losses With losses and simplified description
Magneto Static
Transient Magnetic
