Magnet (unidirectional): demagnetization curve (Hc, Br)
Presentation
This model ( Nonlinear magnet described by Hc and the Br module ) defines a nonlinear B(H) dependence with taking into account of demagnetization, wherever the curve knee is.
Main characteristics:
- the mathematical model and the direction of magnetization are dissociated
- a single material for description of several regions
Mathematical model
In the direction of magnetization the model is a combination of a straight line and an arc tangent curve.
The corresponding mathematical formula is written:
with:
where:
- μ0 is the permeability of vacuum, μ0 = 4 π 10-7 (H/m)
- μrmax is the maximal relative permeability of material
- Br is the remanent flux density (T)
- Js is the saturation magnetization (T)
The shape of the B(H) dependence in the direction of magnetization is given in the opposite figure.
In transversal directions one can write:
B⊥(H)= μ0μr⊥H⊥
where μr⊥ is the transverse relative permeability
Direction of magnetization
The various possibilities provided to the user are the same ones as those presented in § Magnet (unidirectional): linear approximation.
Demagnetization during solving
With this non-linear model, it is now possible to taking in account demagnetization during solving by checking the thick that is provided for. This model is based on a static Preisach model, and can be applied in all over the B(H) law of the magnet:
- Available for 2D and 3D in magnetic transient application
- Initialization by static calculation ( )
- This model does not take in account temperature variations
To use this new model with a solved project :
- Destroy results
- Go in Initialization by static calculation and select :
- Create a new material Nonlinear magnet describes by Hc and Br module
- Check the thick Taking in account demagnetization during solving
- Assign the material to regions
- Go to
- Run the scenario
- Create a new isovalues, select magnet and add BrDemag in the formulas field
Example of results
- This new level of modeling can increase the computation time and the memory (ram & disk)
- Not available in 3D with the potential vector and 2D axisymmetric
