GUI Mode
In order to install Flux Version 2021.2, follow these instructions:
- Close all the applications in use
Download the Flux
2021.2 installer: hwFlux2021.2_win64.exe
from the Altair One site: https://altairone.com/
And save it locally
- Run the executable file hwFlux2021.2_win64.exe
- Select a language
- Click on the OK button
In the Altair
Flux
2021.2 – Windows 64-bit window
(License Agreement panel):
- Scroll through the license agreement and if you accept the terms of the License Agreement, then check the I accept the terms of the License Agreement box
- Click on the Next button to install Flux 2021.2
In the next Altair
Flux
(Introduction panel):
- Click on the Next button to continue installing Flux 2021.2
In the next Altair
Flux
(Choose Install Folder panel):
- Choose an installation directory:
- By default:
- with a user account: the installation directory is C:\Users\<username>\Altair\2021.2
- with an administrator account: the installation directory is C:\Program Files\Altair\2021.2
- You can specify another installation directory, however, make sure that the full directory path does not include any special characters, then click on the Choose button
- By default:
In the next Altair
Flux
(Change Shortcut Folder (Local) panel):
- Specify the folder name that will contain the start menu shortcuts.
- Specify the suffix string to be added to the shortcuts (Optional).
- Select one of the following options:
- Yes if you want to add the Flux shortcut on the desktop
- No if you do not want to add the Flux shortcut on the desktop
In the next Altair
Flux
(Altair License Management System panel):
- Enter the license location:
- If you have a network license, then enter
port@hostname
where port is the TCP/IP port number used by the license server and hostname is the name of the license server computer
- If you have a local license (standalone license), then enter the full pathname of the license file
port@hostname
Note: This window is only displayed if the license has not yet been configured. - Enter the license location:
In the next Altair
Flux
(Pre-Installation Summary panel):
- Click on the Install button to start the Flux 2021.2 installation
In the last Altair
Flux
(Install Complete panel):
- Click on the Done button to complete the Flux 2021.2 installation
