Flow Simulator
Flow Simulator
2021.2
  1. Home
  2. Tutorials
    Discover Flow Simulator functionality with interactive tutorials.
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
  • Graphical User Interface
  • Solver Technical Manual
  • Flow Simulator General Guide
Flow Simulator
2021.2
Flow Simulator
  • What's New
    View new features for Flow Simulator 2021.2.
  • Get Started
    Flow Simulator is an integrated flow, heat transfer, and combustion design software that enables multidisciplinary engineering simulations to optimize machine design
  • Tutorials
    • Tutorial 1: Simple Stationary Flow Network Modelling
    • Tutorial 2: Piping System
    • Tutorial 3: Cooling circuit model of a High-Pressure Turbine (HPT) Nozzle
    • Tutorial 4: Cooling circuit of a rotating turbine blade
    • Tutorial 5: Simple Cavity Model
    • Tutorial 6: High Pressure Turbine (HPT) Stage 1 Blade (S1B) cooling air supply
    • Tutorial 7: Transient Flow Analysis using Feed Forward Controller Model
    • Tutorial 8: PID Controller Tutorial
    • Tutorial 9: Combustor Model
    • Tutorial 10: Probabilistic Tutorial
    • Tutorial 11: MultiCase Tutorial
    • Tutorial 12: Integrated Flow & Thermal Network Model
    • Tutorial 13: Cross Flow Heat Exchanger Model
    • Tutorial 14: 2D Conduction Problem - Thermal Network Model
    • Tutorial 15: Water Hammer Simulation
    • Tutorial 16: Transient Thermal Network for a 2D metal structure
    • Tutorial 17: User Defined Element
    • Tutorial 18: Variable Definition Tutorial
  • Quick Start Guide
Flow Simulator
Flow Simulator
2021.2
  1. Home
  2. Tutorials
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
Tutorials
