Initialize Model
Initializes the internal chamber values (P and T) of entire model with averaged parameter values in order to provide proper start values to the solver. Based on the options selected for “Flow Simulator Chamber Initialization” in “Solver Convergence Panel”, appropriate algorithm is called to initialize the model.
