Check Model
Check the models for Potential Input Errors & Warnings. Users should always run this option before solving the flow/thermal network model. Warning can be ignored if it’s acceptable for users, but Errors need to be fixed before proceeding for the solver run. Clicking on the Error/Warning will go the problem & highlight the same. A sample Check model window is shown below.
