Magnetic Properties
Specify the magnetic properties of the dielectric medium.
- Click the Magnetic modelling tab.
Specify the magnetic properties of the dielectric.
- To create a non-magnetic dielectric, from the Definition method drop-down list select Non magnetic.
- To create a dielectric with frequency-independent-magnetic-properties,
from Definition method
drop-down list select Frequency
independent.
- In the Relative permeability field, enter the value for μr.
- In the Magnetic loss tangent field, enter the value for tanδμ.
- To create a dielectric with frequency-dependent-magnetic-properties,
drop-down list select Frequency list (linear
interpolation).
- To enter each frequency points manually, enter the magnetic properties for each frequency point.
- To import the frequency points from a file, click Import
points.
- In the Filename field, browse for the file you want to import.
- [Optional] In the Scale by
field, enter a value to scale the points.
For example, if you import a value of “2”, scale it by “10e9” to change the value to 2 GHz.
- Under Delimiter, click the delimiter type you use in your file.
- Click OK to close the Import points dialog.
