Cables
Many electromagnetic compatibility and interference problems involve cables that either radiate, irradiate or cause coupling into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
- Cable instance
- A cable instance is a single cable (for example, coaxial cable or cable bundle) with a start connector and an end connector, routed along a cable path.
- Cable harness
- A cable harness is a collection of cable instances along a specific cable path with a specified solution method and cable coupling parameters.
