Media Library
The media library contains a list of predefined and user-defined media. You can either add a predefined medium from the library to your model or add your medium to the library.
On the Construct tab, in the Define group, click the  Media icon. From the drop-down list, select the  Media library icon.
Figure 1. The Media library dialog.
Note: The medium type is indicated in the Source column.
  1. Predefined media (provided as part of the Feko installation) are indicated by the text Altair Feko.
  2. User defined media are indicated by the text User.
