Pin-Fed, Planar Multilayer Substrate Model
Model a microstrip patch antenna using a feed pin and a planar multilayer substrate (Green’s functions). The patch antenna is solved with MoM.
![](../../../../images/feko/example_guide/EG_A08_patch_microstrip_rect/intro_pin_greens.png)
Figure 1. A 3D view of the pin-fed microstrip patch antenna on an infinite ground with symmetry in CADFEKO.
