Finite Antenna Array with Non-Linear Spacing
Calculate the radiation pattern for an array of arbitrarily placed pin-fed patch antennas. Use the finite array tool to construct the array and the numerical Green's function method (DGFM) to minimize computational resources.
![](../../../../images/feko/example_guide/EG_A17_array_finite_non_linear/intro.png)
Figure 1. A 3D view of the finite antenna array with far field pattern in POSTFEKO
