MIMO Elliptical Ring Antenna (Characteristic Modes)
Calculate the current distribution and far fields for a MIMO elliptical ring antenna. Use characteristic mode analysis to calculate the results for different modes.
The analysis is independent of any sources and provide insight into how a structure resonates at the calculated frequencies. This information enables excitation of the structure so that only the desired modes are used.
Figure 1. The first four electric far field modes for the MIMO ring.
