Meshing the Model
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
  1. Set the Mesh size equal to Coarse.
  2. Set the Wire segment radius equal to 0.1.
    Tip: Keep the runtime at a minimum by using coarse meshing to reduce the number of triangles.
  3. Mesh the model.
