Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
  1. Use the model considered in Pin-Fed Patch: Broadside Pattern by Phase Shift Definition and rename the file.
  2. Modify the periodic boundary condition.
    1. Determine the phase shift by setting the beam angle for Theta and Phi to 0°.
