UWB
View the settings for ultra wide band.
Air Interface Parameters
All parameters related with a selected air interface can be specified on the Air Interface tab of the Edit Project Parameter dialog. For ultra wide band mode, the following settings are available:
![](../../../../../images/winprop/user_guide/proman/network_planning_projects/dialog_air_interface_uwb.png)
Figure 1. The Edit Project Parameters dialog, Air interface tab.
- Duplex Separation
- Duplex separation is fixed to simplex, thus only downlink direction is possible.
- MIMO Technology
- MIMO technology is not supported for this air interface.
- Channel Bandwidth
- Available bandwidth of the channel. This value is used to calculate thermal noise impact.
- Carrier Separation
- Frequency separation of two adjacent carriers. This value is used for determination of adjacent or co-channel interference.
Output Options
- Number of Carriers received
