Import and Export Templates
Quickly import and export templates containing full simulation settings, part definitions, or mesh controls.
Note: When importing a template, the names of the parts referenced in the .xml file need to match the part names in the current geometry, otherwise their properties won't be mapped.
  1. From the menu bar, go to File > Template and select an import/export option.
  2. Browse to your working directory and click Open/Save to either import or export an .xml template file.
