2021.1
View new features for Virtual Wind Tunnel for ultraFluidX 2021.1.
Discover Virtual Wind Tunnel for ultraFluidX functionality with interactive tutorials.
File formats supported by Virtual Wind Tunnel for ultraFluidX.
Create a new file.
Open a file.
Import and merge a saved model with the current model.
Quickly import and export templates containing full simulation settings, part definitions, or mesh controls.
Revert to the most recently saved file.
Save all of the data in your current session.
Record a video or take a snapshot of the screen.
Set up a HyperWorks license.
Create and modify sketch curves, PolyNURBS, surfaces, and solids.
Manage the parts and assemblies that make up your model.
Set up your model for analysis.
Submit jobs and view reports.
This section documents the usage of some of the utility scripts that are provided with Virtual Wind Tunnel.
Explore the best practices for ultraFluidX.
Explore the command line options and input file syntax for ultraFluidX.
