2021.1
Discover Virtual Wind Tunnel for ultraFluidX functionality with interactive tutorials.
View new features for Virtual Wind Tunnel for ultraFluidX 2021.1.
Use Virtual Wind Tunnel for ultraFluidX to perform an external aerodynamic analysis of a vehicle.
Create and modify sketch curves, PolyNURBS, surfaces, and solids.
Manage the parts and assemblies that make up your model.
Set up your model for analysis.
Submit jobs and view reports.
This section documents the usage of some of the utility scripts that are provided with Virtual Wind Tunnel.
Explore the best practices for ultraFluidX.
Explore the command line options and input file syntax for ultraFluidX.
