Tutorial: Design Table
Learn how to create design iterations on the fly using a design table, where you can quickly modify and set thresholds for the various parameters of a model, without having to dig through construction history. You can export the file (model with design table) to HyperStudy to test and explore design alternatives.
Open the File
Use the Design Table
Modify Variables
Add the Remaining Variables
- Extrusion length of the cap
- Draft angle of the cap
- Phi Angle of the three section curves
- Diameter of the circle used to sweep the 3 pipes on the main body
