Symmetry
Define the symmetry boundary conditions. You can define up to two symmetry planes. The second symmetry plane must be parallel or orthogonal to the first.
- On the ribbon, click the Die Design tab.
Click the Part icon.
Click the Symmetry icon.
A blue arrow is displayed with an origin point.
Hover over a part to position the symmetry plane, and then click to create the
symmetric copy.
Note: To add a gap between the original part and the symmetric copy, change the Minimum Distance by dragging the yellow arrow or entering a value.
Note: To delete a symmetry plane, select it, and then press Delete. -
To add a second symmetry plane, hold down
Alt while hovering over a part to position the second
symmetry plane, and then click to create the second symmetric copy.
Note: The second symmetry plane must be parallel or orthogonal to the first.
Adjust the symmetry planes.
- Select the symmetry plane you want to adjust.
- Do one of the following:
- In the microdialog, select Plane from
Points. Hover over the model to display blue
points. Click the three desired blue points to precisely define
the symmetry plane.
- Drag the Phi Angle and Theta
Angle arrows.
- In the microdialog, select a reference direction:
Option Description Global X Axis Global Y Axis Global Z Axis Reference Geometry: In the modeling window, click a reference curve. The symmetry plane will correspond to the plane of the reference curve, rather than be tangent to it. Custom : In the modeling window, drag the Phi Angle and Theta Angle arrows, or click one of the arrows and enter an angle. You can also drag the Direction Point. Invert Direction
the symmetry plane.
