Find
Find entities in the model that contain the search string you enter. The search results are not filtered.
  1. Press F2 to open the Model Browser.
  2. Click to open the Find toolbar.
  3. Optional: To control your search, click , and then click one or more of the following options:
    • Match Case
    • Whole Names Only
    • Use Wildcards
  4. In the text field, type a search string.
The first entity that contains the search string is highlighted in the Model Browser
Find Options
Option Description
Navigate to the next or previous entity that contains the search string.
Find every entity that contains the search string.
Access additional options to control the search:
  • Match Case
  • Whole Names Only
  • Use Wildcards
