Search and Filter
Search entities and automatically filter the results to only display the entities that contain the search string. You can also filter by entity type.
  1. Press F2 to open the Model Browser.
  2. Click to open the Search and Filter toolbar.
  3. Optional: To control your search, click , and then click one or more of the following options:
    • Match Case
    • Whole Names Only
    • Use Wildcards
  4. In the text field, enter a search string.
  5. Optional: Filter the search results by entity type:
    1. Click the Filter pull-down menu and select the types of entities to filter.
    2. Click Apply.
Only the entities that match the search string and selected entity type are displayed in the Model Browser.
Tip: Reset the search by deleting the search string and setting the filter to All.
