Inspire Mold is a modern simulation-driven design environment that lets you test, validate, correct, and optimize the design of
injection-molded components.
Show, Hide, and Isolate
Show, hide, and isolate objects in the modeling window using keyboard shortcuts.
Standard and Preset Views
Rotate your model to a standard view, an isometric view, to the closest principal axis, or so that the sketch plane is normal to the grid.
Store and Recall Views
Store a view and recall it so you can capture images from a consistent viewpoint.
Change the Projection
When displaying 3D objects on a 2D plane, you can use perspective projection or orthographic projection.
Fit and Center
Fit or center an individual part or the entire model in the modeling window.
