Dimension
Use the Dimension tool to define and/or constrain the dimensions of a sketch.
The dimension tool can capture:
  • Vertical, horizontal, or aligned distance between a point, vertex, or entity and the sketch origin. (The sketch origin is a projection of the global origin onto the sketch plane.)
  • Vertical, horizontal, or aligned distance between one point or vertex and another
  • Distance between two parallel lines
  • Diameter of a circle
  • Radius of a fillet or arc
  • Angles
Driving Dimensions: These dimensions drive the design intent. They can be edited directly through a microdialog either by entering numbers or assigning variables. Changes to driving dimensions will drive changes to reference dimensions.
Reference Dimensions: These dimensions appear in parentheses and cannot be edited directly.
Tip:
  • Decide which dimensions you will want to edit and capture them first. This is easier than changing them from reference dimensions to driving dimensions later.
  • Once a rectangle sketch has been defined by two dimensions (e.g. length and width) additional dimensions will be captured as reference dimensions by default.
Note: Currently you can only use the Dimension tool on sketch curves.
Apply Dimensions to Sketch Entities
Capture the length of a line, the diameter of a circle, the radius of an arc, or the distance between two sketch entities.
  1. In an active sketch, open the Dimension tool:
    • On the Sketch ribbon, select the Dimension icon OR
    • On your keyboard, press the D key
  2. Select a sketch entity. Dimension previews appear as you move your mouse. If desired, select a second sketch entity to apply a dimension between the two.
  3. Left-click in the modeling window to position the dimension. For driving dimensions, enter the desired dimension in the microdialog.
  4. Optional: To apply a variable, click the icon on the microdialog and select a variable from the dropdown menu, or select Add Variable to create a new variable based on the driving dimension.
  5. Right-click and mouse through the check mark to exit, or double-right-click.
Apply a Variable to a Parameter
Apply a variable to a parameter, or create a new variable on the fly from a tool microdialog.
You can apply existing variables and add new ones via the microdialog in various sketch and geometry tools.
  1. In the tool’s microdialog, click the f(x) icon.
    Figure 1. Example of a microdialog with a variable field
  2. In the dropdown menu, select Add Variable to create a new variable based on the dimension in the text field, or select the name of an existing variable.
  3. Click Apply to apply the variable to the construction feature.
  4. Right-click and mouse through the check mark to exit, or double-right-click.
Tip:
  • You can also create a variable by entering a new name and expression in the microdialog’s text field, for example: Variable1=50
  • In addition, you can also create a new variable based on an existing variable, for example, Variable2=Variable1*0.5.
Fully Define a Sketch
A sketch is fullly defined when its dimensions and its position relative to the point of origin have been defined. A fully defined sketch will appear in black.
      OR
    • On your keyboard, press the D key.
  2. Apply dimensions to the sketch.
  3. Apply dimensions between the sketch and the point of origin.
    Tip:
    The easiest way to fully define a sketch is to start it from the global point of origin.
Edit a Driving Dimension
Reposition, change the value of, or delete a dimensional constraint.
  1. In an active sketch, select a dimension.
  2. In the microdialog:
    • Enter the desired dimension in the text field OR
    • Select the icon the assign a variable to the dimension
  3. Press the Enter key.
  4. Left-click to close the microdialog.
Edit a Reference Dimension
Convert a reference dimension to a driving dimension and edit it.
To edit a reference dimension, you must first convert it to a driving dimension. If a sketch is constrained by driving dimensions, converting a reference dimension to a driving dimension will overconstrain the sketch. You must convert at least one of the driving dimensions to a reference dimension before you can edit any dimension.
  1. In an active sketch, right-click the reference dimension you wish to edit.
  2. Deselect Reference on the context menu.
    The dimension will appear as a driving dimension (without parentheses), but the sketch may now be colored magenta, indicating that it is overconstrained.
  3. Right-click one of the other dimensions. Select Reference in the context menu.
    The dimension now appears in parentheses, indicating that it is a reference dimension. The sketch is no longer colored magenta.
  4. Select the dimension you wish to edit.
  5. In the microdialog:
    • Enter the desired dimension in the text field, OR
    • Select the icon to assign a variable to the dimension.
  6. Left-click to close the microdialog.
