Push, pull, or revolve a face, sketch, line, or 2D edge to extrude it into a solid or surface, create or resize a
hole, eliminate rounds, or modify wall thickness.
A part instance creates a copy of the part that is linked to the original part. When the original part is updated,
the instance is automatically updated as well.
Push/Pull
Push, pull, or revolve a face, sketch, line, or 2D edge to extrude it into a solid or surface, create or resize a hole, eliminate rounds, or modify wall thickness.
Extract
Extract selected geometry features and transfer them to a new part.
Shell
Remove material and create thin walls to generate a shelled part.
Part Instances and Pattern Repetition
A part instance creates a copy of the part that is linked to the original part. When the original part is updated, the instance is automatically updated as well.
Replace Geometry
Replace a part in your model with an alternative design.
