Inspire is a concept design tool which you can use to run structural optimizaiton, finite element analysis, motion analysis,
and additive manufacturing analysis.
Select a curved arrow, and then enter an angle in the microdialog.
Select a curved arrow, and then drag the object.
Tip: Grab and release parts by their snap points (end points,
midpoints, center points, etc.) to align them precisely. You can temporarily
disable snapping by holding down the Alt key.
Right-click and mouse through the check mark to exit, or double-right-click.
