SPH Integration of Continuum Equations
In order to keep an almost constant number of neighbors contributing at each particle, use smoothing length varying in time and in space.
Consider d i the smoothing length related to particle i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ ;
(1)
W j ( i ) = W ^ ( x i x j , d i + d j 2 ) and W j ( i ) = g r a d | x i [ W ^ ( x x j , d i + d j 2 ) ] if kernel correction
or (2)
W j ( i ) = W ( x i x j , d i + d j 2 ) and W j ( i ) = g r a d | x i [ W ( x x j , d i + d j 2 ) ] without kernel correction
At each time step, density is updated for each particle i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ , according to:(3)
d ρ d t | i = ρ i v | i
with (4)
v | i = m j ρ j ( v i v j ) W j ( i )
Where,
m j
Mass of a particle i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@
ρ i
Density
v j
Velocity
Strain tensor is obtained by the same way when non pure hydrodynamic laws are used or in the other words when law uses deviatoric terms of the strain tensor:(5)
d v α d x β | i = m j ρ j ( v i α v j α ) d W j d x β ( i ) , α = 1...3 , β = 1...3.
Next the constitutive law is integrated for each particle. Then Forces are computed according to:(6)
m i d v d t | i = j V i V j [ p i W j ( i ) p j W i ( j ) ] j m i m j π i j [ W j ( i ) W i ( j ) ] 2
Where ρ i and p j are pressures at particles i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ and j MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ , and π i j is a term for artificial viscosity. The expression is more complex for non pure hydrodynamic laws.
Note: The previous equation reduces to the following one when there is no kernel correction:
(7)
m i d v d t | i = j V i V j [ p i + p j ] W j ( i ) j m i m j π i j W j ( i ) ,
since W i ( j ) = W j ( i )
Then, in order particles to keep almost a constant number of neighbors into their kernels ( ρ d 3 is kept constant), search distances are updated according to:(8)
d ( d i ) d t = d i v | i 3
