OS-E: 0185 Rubber Ring: Crush and Slide Using Self-Contact
Demonstrates self-contact which is used in this nonlinear large displacement implicit analysis involving hyperelastic material and contacts using OptiStruct.
Model Description
A deformed rubber ring resting on a flat, rigid surface. Another circular rigid roller rests at the top of the ring, and is in contact with the ring at just a point. Contact is defined between the rigid surfaces and the outside surface of the ring and self-contact is defined in the inside surface of the ring. The loading is applied in two steps – in the first step, the circular roller is pushed down enough to produce self-contact of the inside surface of the ring. In the second step, the roller is simultaneously translated and rotated such that the crushed ring rolls along the flat rigid surface producing a constantly changing region of contact. Here the nonlinear implicit analysis is run.
- Rubber Ring
- First order solid elements
- Shell Elements
- Roller
- First order shell
- Flat Floor
- First order shell
- Young’s Modulus
- 210000 MPa
- Poisson's Ratio
- 0.3
- Initial Density
- 7.9×10-9 ton/mm3
- Poisson's Ratio
- 0.495
- Initial Density
- 1.1×10-9 ton/mm3
- Coefficient of Thermal Expansion
- 1.7×10-4K-1
Results
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/rubber_ring.fem
