OS-E: 0110 Elastic-Plastic Large Displacement Analysis
Large displacement analysis of a dog-bone type tensile coupon with elastic-plastic material properties is demonstrated in this example.
Model Description
The coupon undergoes a simulated tensile test, where one end is held via a series of single point constraints – colored in blue in Figure 1. The other end is drawn along the positive x-axis via an enforced displacement applied at the center of the rigid element – colored in green in Figure 1.
- FE Model
- Dog-bone
- CHEXA8
- Spider-Rigid
- RBE2
- Young’s Modulus
- 210,000 N/mm
- Poisson's Ratio
- 0.3
- Yield
- 306 N/mm
- Plastic Strain
- TABLES1 data
Results
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/ElasticPlasticMaterials_LGDISP.fem
