OS-V: 0210 Simply-Supported Thick Square Plate
Test 21OptiStruct is used to investigate the repeated eigenvalues and the effect of ‘secondary’ restrains.
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 1.0m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10.
- Material Properties
- Value
- Young’s Modulus
- 200 × 109 N/m2
- Poisson’s Ratio
- 0.3
- Density
- 8000 kg/m3
Modal Analysis Results
f*
- Closed form solution
Mode 1 | Modes 2 and 3 | Mode 4 | |||
f* |
45.897 Hz | f* |
109.44 Hz | f* |
167.89 Hz |
HOE | 1.013827837 | HOE | 1.044863043 | HOE | 1.046793653 |
LOE | 1.005851414 | LOE | 1.002363027 | LOE | 1.034589005 |
Modes 5 and 6 | Modes 7 and 8 | ||
f* |
204.51 Hz | f* |
256.50 Hz |
HOE | 1.125821617 | HOE | 1.094829757 |
LOE | 0.993823531 | LOE | 1.051061511 |
Model Files
The model files used in this problem include:
- /Test21HOE.fem
- /Test21LOE.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
