OS-V: 0200 Simply-Supported Thin Square Plate
Test No. 13OptiStruct is used to investigate the repeated eigenvalues.
Figure 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 0.05m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10.
The material properties are:
Material Properties
Value
Young’s Modulus
200 x 109 N/m2
Poisson’s Ratio
0.3
Density
8000 kg/m3
Modal Analysis Results
The frequency of each targeted mode is normalized with the closed form solution.
f*
Closed form solution
Mode 1 Mode 2 and 3 Mode 4
f* 2.377 Hz f* 5.942 Hz f* 9.507 Hz
HOE 1.021926053 HOE 1.066977913 HOE 1.076061121
LOE 1.013646055 LOE 1.015552897 LOE 1.053290494
Mode 5 and 6 Mode 7 and 8
f* 11.884 Hz f* 15.449 Hz
HOE 1.176750173 HOE 1.175007606
LOE 1.002869198 LOE 1.065889334
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification
  • Test13HOE.fem
  • Test13LOE.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
