OS-V: 0280 Axisymmetric Elements - Interference Fit Between Two Cylinders
The model examines the contact pressure between two cylinders in case of interference fit of 20 mm.
Figure 1. Model and Loading Description
Benchmark Model
2D axisymmetric elements (CQAXI) elements are used to model 2 cylinders.
A minus gap clearance of 20mm was used to analyze interference fit between the cylinders. The cylinders are vertically fixed. Stationary frictionless contacts are used.
Material Properties
Value
Young's modulus
206 GPa
Poisson's ratio
0
Nonlinear Static Analysis Results
Static analysis was carried out using 1 increment.
OptiStruct NAFEMS Normalized Target Value
Contact Pressure 2.35 2.27 1.035
Figure 2. Contact Pressure Between the Cylinders
Model Files
The model file used in this example includes:
<install_directory>/hwsolvers/demos/optistruct/verification/Interference_fit.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
