Fatigue Process Manager (FPM) using S-N (Stress - Life) Method
OptiStruct uses the S-N approach for calculating the fatigue life. The S-N approach is suitable for high cycle fatigue, where the material is subject to cyclical stresses that are predominantly within the elastic range. Structures under such stress ranges should typically survive more than 1000 cycles.
Figure 1. Low Cycle and High Cycle Regions on the S-N Curve
Figure 2. Two segment S-N Curve
In OptiStruct various stress combination types are available, with the default being "Absolute maximum principle stress". In general "Absolute maximum principle stress" is recommended for brittle materials, while "Signed von Mises stress" is recommended for ductile material. The sign on the signed parameters is taken from the sign of the Maximum Absolute Principal value.
In this tutorial, you will be able to evaluate fatigue life with the S-N method through process manager step by step.
Launch HyperMesh and Process Manager
Import the Model
