OS-T: 1393 Basics of Contact Properties and Debugging
This tutorial demonstrates the effect of using contact stabilization, clearance, and adjust.
The model consists of two circular parts where the inner one is heated and the outer one cooled down, leading to contact between the two.
The initial model will fail to converge, and usage of contact stabilization will be demonstrated to help achieve the convergence. Further, definition of contact settings such as clearance and adjust will be demonstrated. Exercises covered in this tutorial are:
  • Launch HyperMesh and import the model
  • Definition of contact property with friction
  • Run the model to encounter convergence issues
  • Overcome convergence issue with contact stabilization
  • Definition of contact clearance and adjust
  • Comparison of the results in HyperView
os_1393_model
Figure 1. Illustration of the Model
Launch HyperMesh and Set the OptiStruct User Profile
  1. Launch HyperMesh.
    The User Profile dialog opens.
  2. Select OptiStruct and click OK.
    This loads the user profile. It includes the appropriate template, macro menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for OptiStruct.
Import the Model
  1. Click File > Import > Solver Deck.
    An Import tab is added to your tab menu.
  2. For the File type, select OptiStruct.
  3. Select the Files icon files_panel.
    A Select OptiStruct file browser opens.
  4. Select the contact_S2S.fem file you saved to your working directory. Refer to Access the Model Files.
  5. Click Open.
  6. Click Import, then click Close to close the Import tab.
    The outline of the Fatigue Analysis setup to be achieved in the following steps.
Set Up the Model
Create a PCONT Property
The base model already contains the material, property, boundary conditions and the loadstep definitions. Contact surfaces and the contact interface has also been defined.
A PCONT property is created to define friction, which will be referenced to the already created contact interface.
  1. In the Model Browser, right-click and select Expand All.
  2. Right-click on the Model Browser, and select Create > Property to create a PCONT property.
  3. For Name, enter cont_prop.
  4. Click the drop-down menu next to Card Image and select PCONT.
  5. In the MU1 field, specify a value of 0.2 for the coefficient of static friction.
    os_1393_pcont
    Figure 2. Contact Property Definition
  6. In the Model Browser, select the interface contact_interface.
  7. Click the drop-down menu next to Property option and select Property Id.
  8. For PID, select cont_prop property.
Submit the Job
  1. From the Analysis page, enter the OptiStruct panel.
    OS_1000_13_17
    Figure 3. Accessing the OptiStruct Panel
  2. Click save as following the input file field.
    The Save As dialog opens.
  3. Select the directory where you would like to write the OptiStruct model file and enter the name for the model, contact_S2S.fem, in the File name field.
    For OptiStruct input files, .fem is the recommended extension.
  4. Click Save.
    The name and location of the contact_S2S.fem file displays in the input file field.
  5. Set the export options toggle to all.
  6. Set the run options toggle to analysis.
  7. Set the memory options toggle to memory default.
  8. Click OptiStruct. This launches the OptiStruct job.
    If the job is successful, the new results files will appear in the directory where the input file was saved. Look in the contact_S2S.out file for error messages that could help debug the input deck, if any errors are present.
    It can be noted that this model will encounter convergence issues and the job errors out. In the upcoming sections, different contact settings will be demonstrated to help the model achieve convergence.
Add Contact Stabilization
Since the non-linearity of this model is only due to contact, a good way to overcome the convergence issue is to add contact stabilization. This will especially be useful when part of the structure is held in place by the contact, which is the case here.
  1. Click Setup > Create > Control Cards.
  2. Select PARAM and check the box next to EXPERTNL.
  3. Select CNTSTB to activate contact stabilization.
    Note: Contact stabilization can also be activated through the CNTSTB Bulk Data Entry, which can be referenced in the subcase. This method provides more options to define contact stabilization.
  4. Repeat Submit the Job, with the new file name contact_CNTSTB.fem.
    os_1393_param_exprtnl
    Figure 4. Creating PARAM,EXPERTNL,CNTSTB
    Note: The model converges successfully in the presence of contact stabilization.
Add Clearance
Now the influence of contact clearance will be shown in the model.
  1. In the Model Browser, select the cont_prop property.
  2. In the Entity Editor, click on the field next to CLEARANCE and enter the value 0.1.
    Clearance will internally set the gap between the surfaces to the real value chosen, irrespective of the actual position of the grids, if grids are not moved to achieve this.
    os_1393_cont_prop
    Figure 5. Contact Property Definition through PCONT
  3. Repeat Submit the Job, with the new file name contact_clearance.fem.
Add AUTO Adjust
Now, influence of adjust will be shown in the model. First, the contact clearance that was defined in Add Clearance will be removed.
  1. In the Model Browser, select the property cont_prop.
  2. Click on the field next to CLEARANCE and remove the previously specified value of 0.1.
  3. In the Model Browser, select the interface contact_interface.
  4. Click on the field next to ADJUST and select AUTO.
    os_1393_cont_interf
    Figure 6. Definition of ADJUST in the Contact Interface
Apply Surface Smoothing
Repeat Submit the Job, with the file name contact_adjust.fem.
View the Results
Displacements, Element Stresses, Contact Force, Contact Deformation, Contact Status and Contact Traction are calculated and can be plotted using the Contour panel in HyperView.
Compare the Contact Traction
Compare the Contact Traction between the different cases.
  1. Launch HyperView.
  2. Select the page window layout icon to split the page into 3 windows.
  3. Click fileImportModel-24 to load the first model in one of the window.
  4. Select contact_CNTSTB.h3d for model and results.
  5. Click Apply.
  6. Do the same in the other two windows for contact_clearance.h3d and contact_adjust.h3d.
  7. Click the Contour toolbar icon resultsContour-16 in one of the three windows.
  8. For Result type, select Contact Traction/Normal(s).
  9. Click Apply.
    os_1392_contour_plot
    Figure 7. Contour Plot Panel in HyperView
  10. In the Entity Editor, unselect the outer part of the structure.
    Only the results on the contact surface will be visible.
  11. Right-click in the window that shows the contour and select Apply Style > Current Page > All selected to view the same results for all models.
    os_1392_apply_style_menu
    Figure 8. Apply the Setup in One Window to the Rest of the Page
  12. A contour plot of normal contact traction shows for both runs.
    The traction for the models with clearance and adjust are more uniform than they are for the model with stabilization only. In addition, the peaks are much lower for these three models. In case of adjust, the gap is closed initially, leaving less room for stress free thermal expansion compared to the other cases. Hence, the contact traction is higher in this case adjust compared to the results with clearance.
    os_1393_contact_traction
    Figure 9. Normal Contact Traction Contour for the Three Different Runs
