MV-1023: Use Python Subroutines in MotionView Model Building
In this tutorial, you will learn how to incorporate user subroutines into MotionView, utilize user subroutines to customize models, and create Python scripts to define these subroutines.
To complete this task, you must be familiar with the MotionView user interface and entities panel, as well as have some experience defining and modifying entities. Some experience with the Python programming language is necessary to fully understand the topics covered.
The objective of this tutorial is to replace several entities in a MotionView model with Python user subroutines. You will run the model initially and then edit the file to incorporate Python scripts in place of MotionView entities and compare the results from each simulation.
