Point Macros Toolbar
The Point Macros toolbar provides you quick access to the Create Points using Coordinates, Create Points Along a Vector, Create Points Along a Curve, and Create Point at Arc Center macros.
Figure 1. Point Macros Toolbar
Left-click the corresponding button on the toolbar to display the window or panel for the selected item:
Create Parametric Points Allows you to create a set of points with respect to a reference marker either in Cartesian coordinates or Cylindrical coordinates.
Create Points on a Vector Allows you to create a set of points along a vector.
Create Points Along a Curve Allows you to create a set of points along a curve.
Create Points at At Arc Center Allows you to create a point at the center of an arc.
Create Curve From Points/Nodes/Edges/Faces Allows you to create curve graphics from a set of selected points or nodes.
