Container Entity Toolbar
The Container Entity toolbar provides you quick access to the System/Assembly, Analysis, and Command Sets panels.
Figure 1. Container Entity Toolbar
Left-click the corresponding button on the toolbar to set the filter for picking items in the graphics area to the currently selected entity/panel only, or right-click to display the Add "Entity" dialog (which is used to add entities to the current model):
System/Assemby Allows you to create and save systems/assemblies, to modify system/assembly attachments, and to set system options and initial conditions.
Analysis Allows you to create and save an analysis, to modify analysis attachments, and to set analysis options and initial conditions.
Command Sets Allows you to create command sets for the solver-command file. The command sets for a model are order dependent since they define the contents of the solver command file.
