Load Export
An external module invoked from MotionView. This module allows you to take loads from an ADAMS run and create a tabular summary file or a Nastran input card for those loads.
The Load Export utility helps bridge the gap between multi-body dynamic (MBD) analysis and finite element analysis (FEA) by:
  • Identifying and summarizing all loads acting on one or multiple bodies for any give time step(s) in a tabular format
  • Identifying and transferring all the forces and moments on one component at any given time step(s) to a Nastran input deck that contains GRID, CORD, FORCE, and MOMENT cards.
The Load Export utility is used in conjunction with MotionView to perform the above mentioned functions. To use this utility, you must specify the components in an MBD model for which loads are to be processed. You can do this by using the MotionView GUI or editing the MDL MBD model file to add force output requests on bodies. After an MBD analysis on a model using ADAMS, you will get an ADAMS request file and a metadata file (a MotionView ASCII file that contains information of force output on a body) that are used as the input files for the utility. The application scope of Load Export is shown below:
Figure 1. Interaction diagram
Metadata File Generation and Format
MotionView supports force requests on body entities. To provide detailed information about the forces acting on a given body entity, MotionView automatically generates a metadata file if there are active force requests on body entities in the active model. For more information, see the Metadata File Generation and Metadata File Format topics.
To run the Load Export utility:
From the FlexTools menu, select Load Export.
  • The Load Export utility is displayed.
