Check Model
Check Model searches for unresolved references and invalid data in the model. If errors in the model are detected, it is reported in the message window that is displayed when the check is completed.
The types of checks that are conducted are specific to entity types. Check Model detects errors such as negative mass for a body and negative diameter for a beam.
  1. From the Tools menu, click Check Model.
    A message window displays the check status. When the check is complete, the model errors are listed in the message window.
  2. From the Analyze ribbon, Simple Run tool group, click the Check tool.
