Adding an Inline Analysis to the Current Model
  1. Right-click on the Model label and select Add > Analysis.
    The Add Analysis dialog is displayed.
  2. Activate the Inlined in model file radio button and click Next.
  3. Assign a variable name to the analysis.
    The variable name is required and cannot be changed after it is defined.
  4. Assign a label to the analysis.
    The system label can be changed at any time.
  5. Assign a definition name to the analysis.
  6. Click OK to close the window and add the analysis to the model or Apply to continue creating inline analyses.
