Adding an Analysis to the Current Model Using an Existing Data File
  1. From the Add Analysis dialog, activate the Uses data and definition files radio button and click Next.
  2. Activate the Existing data file radio button and click Next.
  3. Click the Existing Data File broswer icon.
    The Select Data File dialog is displayed.
  4. Browse and select the data file that you want to use, and then click Open.
    The definition file, name, and type referenced by the data file are automatically displayed in their respective fields.
  5. Assign a label to the analysis.
  6. Click OK to close the window and add the analysis to the model or Apply to continue creating analyses.
