pltIAxis GetMax
Gets the maximum value for the axis.
pltIAxis GetMax
HyperWorks Tcl Query
Returns the maximum value for the axis.
Error
None.
View new features for HyperWorks Desktop 2021.1.
Displays current state of the Axes panel's Lock option.
Gets the color of the axis.
Gets the dB10 reference value for the axis.
Gets the dB20 reference value for the axis.
Gets the display value when the real value is input.
Gets the spacing between tics for the axis.
Gets the label (displayed text) of the axis.
Gets a handle to an hwIFont interface for the label font of the axis.
Display the current state of the Axes panel's Lock option for selected axis.
Gets the minimum value for the axis.
Gets the title of the axis.
Gets the number of grids between tics on the axis.
Gets the number of tics for the axis.
Gets the format used for displaying tics on the axis.
Gets the number of decimal places displayed for tics on the axis.
Gets the real value when the display value is input.
Gets the scale type for the axis.
Gets the method used for placing tics on the axis.
Gets a handle to an hwIFont interface for the tics font of the axis.
Gets if the axis is displayed or hidden.
Gets the weighting type for the axis.
Sets one of the three Lock option states for the axes.
Sets the text color of the axis.
Sets the dB10 reference value for the axis.
Sets the dB20 reference value for the axis.
Sets the spacing between tics for the axis.
Sets the label (displayed text) of the axis.
Sets one of the three states for the selected axis.
Sets the maximum value for the axis.
Sets the minimum value for the axis.
Sets the title of the axis.
Sets the number of grids between tics on the axis.
Sets the number of tics for the axis.
Sets the format used for displaying tics on the axis.
Sets the number of decimal places displayed for tics on the axis.
Sets the scale type for the axis.
Sets the method used for placing tics on the axis.
Sets whether the axis is displayed or hidden.
Sets the weighting type for the axis.
ON THIS PAGE
pltIAxis GetMax
None.
ON THIS PAGE
